Marvel Mystery Oil
My snowmobiles have never had engine problems due to not fogging them in the fall. Just mix the oil with 30 wt., take out the plugs, pour in a cap full, pull the rope a few times and put the plugs back in. In fall start it up, let it run, then put in new plugs. Snowmobiles are notorious for burning up crank bearings if not winterized properly.
I do the same thing to my outboard engine. The sucker starts on the second pull each spring. Its a 7.5 Evinrude 1980ish.
I pour the mix down the carb on the Sea-Ray each fall while the engine is running.
So, I do not see any benifits except I feel my toys are being properly maintained, and the MMO is part of it.
I've been using it for eons! If it ain't broke, don't fix it!
I use in all of my vehicles oil. Never tried the boat engine, but will when i get another one.
You can you burn it in your Outboards(2cycle)? Havent heard of that but I dont know.
Also it says you can put it in your fuel, anyone ever tried that?
