383 Street Engine / balancing issue >
Old 02-06-2013 | 04:20 PM
Default 383 Street Engine / balancing issue
Hi,
I want to fit two 383 Street Engines ( crate blueprint) in my boat. I know i Need to change the Cam and the Core plugs, but what Happens with the crank balancing ? All Engines are Balanced external. ( flexplate/ balancer) if l Take now my existing balancer and flywheel the balancing is gone.. What is to do? Or is it a misunderstanding on my side?
Thanks for your help
Daniel
Komo is offline
Old 02-06-2013 | 04:26 PM
Why not spend the extra money for Blueprint's marine engines?
boats74 is offline
Old 02-06-2013 | 04:30 PM
GPM
Are the new engines internal or external balance ? You probably want to run stainless head gaskets.
GPM is online now
Old 02-06-2013 | 04:52 PM
you could buy 400 small block clutch flywheels. repros are pretty cheap. can still find orig ones on ebay-craigs. but truly blueprinted motors are balanced to that wheel, not a generic standard. so, unless you already own these street motors, it doesn't make sense. but if you are using stuff you already have and don't wanna send motors back to be torn down and rebalanced, that would be the way to go. use the balancers that are on the 383's and buy the flywheels.
dereknkathy is offline
Old 02-06-2013 | 05:44 PM
boats 74: I will spend the extra money but I need the alloy heads to lower the wheight..
Komo is offline
Old 02-06-2013 | 05:48 PM
dereknkathy: thanks for the help. I`m not sure why Blueprint did not add the parts to the engines if they sell it... The balancer could be find in web but I cannot find a flywheel.. :-(
They advice "This engine requires a 400ci weighted harmonic balancer, and late 350ci weighted flexplate/flywheel."
Komo is offline
Old 02-10-2013 | 03:02 PM
they are mistaken on the flywheel. look on ebay. put 400 chevy clutch flywheel in the search block.
Old 02-10-2013 | 03:18 PM
350's are typically externally balanced. 400's are typically internally balanced.
When going the stroker route (using the 400 crank) it reverts to an internally balanced assembly. You can either buy a 400 flywheel OR have somebody mill the weights off the 350 flywheel.
Trash is offline
Old 02-11-2013 | 02:44 PM
Default balancing
My personal experience with the mentioned manufacturer. I had a customer buy two marine 383s received them installed and experienced a vibration on both engines I called the manufacturer and asked what components the customer should use. The answer was suprising to me "I don't know we take the crankshafts out of the box and install them we don't balance them" the person I spoke to identified him as the owner of the company and there was no one else in the technicall department.
Let me explain something to help put this in perspective for people who buy mail order engines. When you buy a balanced rotating assembly and it doesn't include a balancer and flywheel you are not buying a balanced assembly, the components that are bolted to the crankshaft can not be assumed to be balanced, they must be balanced as an assembly and don't let any one tell you you can take any component off of any engine and your balance will be fine this happens at least once a year on oso. The purchase of a marine or performance engine should researched carefully and the customer should visit the engine facility these purchases should never be made blind folded unless you have alot of time and money. Sincerely Laz Mesa
www.mesabalancing.com
MESABALANCING is offline
Old 02-11-2013 | 03:52 PM
GPM
That's backwards, 400 sbc is external, 350 is internal balance. A 383 can be either depending on what parts you use.
GPM is online now
