Trailer redo
Well besides some finishing touches I`m finally done.
Trailer started needing some TLC
only pic I got on the trailer lol:
Sandblasted, 2 part epoxy primer and paint to match boat:
All carpeted wood filler pieces replaced with heavy gauge diamond plate
Also added my version of a drive guard plus all new tires
All new electric brakes, seals and bearings.
Pulled every wire and ran all new thru out.
Every connection is soldered + dialectic grease + 2 layers of heat shrink. (this took the longest to do)
Every bolts and negative connection is stainless steel.
LOVE this thing!
LOVE this thing!
All new bunks and carpet:
Finally I went crazy with the LEDS:
under the trailer too following the red/white theme.
Side turn signal under the marker lights.
I should be able to see the bottom of any launch I`m hoping
Looks great!
I'm getting ready to do the same to mine...two questions:
What did you do with the brake lines prior to sandblasting?
Did you have the boat pulled off or did you have access to another trailer?
She don`t quite fit thou :
Wish I had a nice big pole barn like Mike Tcat but ....I don`t
so I red neck it up
BTW, anyone local to Chicagoland area looking for paint, sandblast etc.. the guy I found did a great job at a great price.
To sandblast, prime and paint was under $1000. He also ran new wires, cut and fit the diamond plate and built the drive guard . All that around $1800.
Can`t beat that, I had another quote for just paint at $5K
http://www.manta.com/c/mx2c6h8/renew...efinishing-llc
Located in Addison
Thanx Joe! Its nice to have it done.. trying to work on two projects.. boat and trailer at the same time was burning me out.
I`m also looking for these center caps I had on the Baja.. don`t seem to be able to find them anywhere.. ??
