Hyd steering advice >
Hyd steering advice
Hyd steering advice
Old 02-08-2013 | 03:52 PM
Default Hyd steering advice
I am looking to upgrade my stock bravo 1 steering. I have read several things about add on kits and full hydraulic. Is there any disadvantage to the add on kits? Is there a preferred brand? Will both versions eliminate the slop in the system.
Cheetah is offline
Old 02-08-2013 | 06:58 PM
imco makes a affordable system.yes it should get the slop out,disadvantages maybe cost.good luck and thier well worth it.
innerrage is offline
Old 02-08-2013 | 07:15 PM
Go full for sure. Zeiger is good also. Actually I haven't heard anything bad about any of the major manufacturers.
thirdchildhood is offline
Old 02-08-2013 | 07:25 PM
Dave M's Avatar
Veteran: Navy
I would opt for a FULL single ram system over a twin ram add-on assuming the boat is <30' and cost is a factor.
Dave M is offline
Old 02-08-2013 | 07:51 PM
On a single engine application the turn radius is reduce. I would opt for full hyd also
goebel1 is offline
Old 02-08-2013 | 08:41 PM
You are still relying on the cable and manual helm with the add-on kit. Unless you just want to tighten it up a bit def. go full hyd. It's worth it.
RAPTOR1 is offline
Old 02-08-2013 | 11:46 PM
I will be putting the system on a 24 foot essex valor. I am installing a whipple on the 496 ho and should be in the high 70s when finished. I already have slop in the steering and I've heard about safety concerns with th stock set up at those speeds. The way I understand it, either add on or full system will address the safety concern but he full hydraulic sounds like a better system. Let me know if I am off track.
Thanks for the advice.
Cheetah is offline
Old 02-09-2013 | 04:15 AM
As stated go with a full system, big difference (I have had both).
badluck is offline
Old 02-09-2013 | 05:22 PM
I picked up a used Imco add on. Primarily for safety reasons (+80 gps in a 23 Nova). I noticed no reduction in turning radius, and less slop in the steering.
Those who have full swear by it, but the add on works ok for me.
Kidnova is offline
Old 02-10-2013 | 02:53 PM
Check out the Mayfair kits, best bang for the buck. I have the external cylinder but still have the cable helm. I will be changing to full hydraulic this spring, the slop in the cable is unnerving at anything over 80.
ThisIsLivin is offline
