454 330 turned into 496 stroker
I have a stock 454 330 that is tired and wore out.
So I'm Turing it into a 496 bbc
60 over on the block
Forged crank
Manley h-beam rods
Crane gold rockers
Sumit racing oval port heads
What is recommended for Intake and carborater
I have an edlebrock 750 but won't be enough I don't think.
Just looking for
Pistions
Valves
Intake
Carb
cam and i need some ideas
Any suggestions and thought please and thanks
Any thought on setup would also be help full
It's going in a 24 predator marine viper
4000lbs
With imco ext. box with dual hydrolic steering
Bravo 2 upper with brave 1 lower
Forged crank
Manley h-beam rods
Crane gold rockers
Just looking for
Pistions
Valves
Intake
Carb
4000lbs
I would put in a roller cam. RMbuilder on this site can get you the right cam. You shuld be able to pull 525=550 hp no prob. The intake that come with the Merc HP 500 is a good manifold and and with a 850 cfm carb you should be fine. BTW make sure you check the block for clearances on the rod journals.
Good luck with the build.
Wannabe
Wannabe
I'm not using pro comps, but have a few friends who use them (auto application) with good results. They buy bare casting and build the heads. One guy runs low 8's with them. They make good power and are dirt cheap. Think he gets them for 300 a cylinder bare casting. It sure is temping to throw a set on ad do away with my 088's.
on a boat,the alunimum in pro comp heads is for chit when you cool the engine with just water,,with just water the castings ware away real fast and the end results are total distruction of the engine...look up flying tomato and see what happened to his engine..
Your valvetrain alone roller cam, lifters, pushrods, roller rockers, springs, retainers, severe duty intake valves, extreme duty inconel exhaust valves is going to set you back over 2K EASY.
Your still going to need the forged crank, manley rods, forged pistons, pair of heads, timing set, intake, carb, fuel pump, oil pan, valve covers, flame arrester, gaskets,machine shop work
