240 sport windshield >
Old 02-13-2013 | 04:01 PM
Default 240 sport windshield
any idea if a 265 force windshield is the same as a 240 sport specifically the side pieces. i called taylor made but they need a part number to cross refence and good luck getting ahold of baja they never answer the phone. i have a 265 force parts boat with a good windshield hoping its a direct fit any info on this would be greatly appreciated.
ThunderFanatic is offline
Old 02-13-2013 | 04:27 PM
Honestly I think they're alittle different the 265 I believe has a bigger windshield. Either XT will chime in he is the Baja expert. You can email him also. Very knowledgeable. If you want I can measure my 240 side glass for you if you'd like.
mickeymcclgn is offline
Old 02-13-2013 | 09:38 PM
Custom Interiors & More
Default Thanks Mickey
The Taylor Made part number for the 240 Sport windshield is #179684. It was also interchangeable with the 220 Sport. The Baja 265 is a taller windshield that only interchanges with the Baja 235 model. I just got a parts 240 windshield for my 220 this week, and I promised one side wing to another OSO member. What side glass do you need?
http://www.offshoreonly.com/forums/b...220-sport.html
XT
XT-Innovator is offline
Old 02-14-2013 | 12:18 PM
XT, I have a 235, and some of the plastic "piping" that covers the channel where the wiring runs has shrunken / broken off. Is this stuff still available? What about the weatherstrip that holds the glass?
How difficult is removal / replacement of these windshields? I would like to take mine apart and have the frame bead blasted and powder coated silver. Never been a big fan of the black - gets hot, and it rubs off where the cockpit cover rubs over it.
Thanks!
Budman II is offline
Old 02-14-2013 | 10:06 PM
Budman,
I would send a small sample of each item to Taylor Made and indicate the length needed.
XT
Old 02-14-2013 | 10:18 PM
Thanks XT, I will try that. How hard is it to remove the windshield and disassemble it?
Old 02-15-2013 | 11:32 AM
XT
Thanks for the info on that XT I need the port side. It to a shot to the side blew the glass out and bent the top frame piece luckily that's all it came out with for damage.
Old 02-15-2013 | 03:02 PM
I bought my 220 Sport with someones clear plexiglass job that looked like crap for the two front panels. The 240 Sport donor boat windshield I purchased is a perfect match to my 220 and as I disassembled the side wings I noticed the glass pattern is the same for both sides and only the frame is different. I need to put together the best set on my project, but I should have good glass for two repairs, but only one set of Port side frames to sell. They are easy to take apart with just a 1/8" drill bit on the rivets.
XT
www.xt-innovationsDOTcom
Attached Thumbnails 240 sport windshield-dscn1557.jpg   240 sport windshield-dscn2363.jpg   240 sport windshield-dscn2364.jpg
Old 02-28-2013 | 11:36 AM
XT
Sorry it's taken so long I've been real busy but how much would you be looking to get for at least a piece of glass? All I really need for the port side wing is the top track the rest is fine but the top looks like a banana no saving that piece.
Old 02-28-2013 | 01:11 PM
PM Sent, but inbox was full.
