First On-Water Impression: Ilmor MV8 570-Powered Formula 353 FAS3Tech >
Old 02-13-2013 | 06:24 PM
Jason Johnson's Avatar
Correspondent
Correspondent
Default First On-Water Impression: Ilmor MV8 570-Powered Formula 353 FAS3Tech
Speedonthewater.com brings your our first impression of Ilmor's new MV8 570 engines. Check out the story, photos and video...
http://speedonthewater.com/new-boats...-fas3tech.html
Jason Johnson is offline
Old 02-13-2013 | 06:28 PM
Nice write up and read.
Those motors look amazing sitting in that Formula and 81 is pretty good for an out the box package.
Nate5.0 is offline
Old 02-13-2013 | 08:03 PM
sounds like they need to try some 24 or 26 bravos, the maximus are good midrange and low speed props, the blades are to big for good top end.
pstorti is offline
Old 02-13-2013 | 08:58 PM
C_Spray's Avatar
Diamond Member #001
Needs 1.65 gears and some high-rake props. Taking 450 pounds out of the back of that boat will require a bit of tuning. Can't wait to hear these beasts tomorrow!
Thanks, Matt!
C_Spray is offline
Old 02-13-2013 | 09:02 PM
What a screamer! Sounds awesome!
Do they make XR gears in 1.65:1?
Back4More is offline
Old 02-13-2013 | 09:39 PM
I thought it was SCX upper? 1.50 is as low as it goes.
professor_speed is offline
Old 02-14-2013 | 07:14 AM
Correspondent
Correspondent
You make a very good point. The drive gear change notion came out of post-ride dock talk, without online access or the Teague or IMCO catalogs in hand. I will talk with Bob Teague and, if he's here in Miami, Fred Inman today and see what they might suggest along these lines.
And then I'll get back to you.
Matt Trulio is offline
Old 02-14-2013 | 07:34 AM
Thanks, Matt!
Needs something, because while loving the paint and the sound of the engines i am pretty let down on the speed it ran
Car Biz is offline
Old 02-14-2013 | 07:39 AM
Knot 4 Me's Avatar
Curious as to why they did not package the Indy drive with this motor?
Knot 4 Me is offline
Old 02-14-2013 | 07:54 AM
Overkill for the low HP - and much more expensive.
Marginmn is offline
