Outdrive Positioning >
Old 02-18-2013 | 11:03 AM
Default Outdrive Positioning
Gentleman , as I move my project along , the next big decision is how far apart to set my drives. The boat is a side by side Flat Deck as most are aware . The drives are currently spaced 36.125 inches apart. I have had varing opinions as to how close I can set them without having serious issues mounting exhuast and hatch rams. I am currently running tubular headers . Does anyone know what the topgun drive distance is, at the lreast what your boat is running for power and how close your drives are?
Thanks In advance. RG.
Rick G is offline
Old 02-18-2013 | 01:49 PM
If it helps you just let me know what measurements you`d need..
I got pics of the inside too:
ICDEDPPL is offline
Old 02-18-2013 | 02:19 PM
ICDEDPPL . thanks I need the distance from center of one drive to other . The easiest place to measure would the distance between the grease fittings at the top of your gimbals . I am guessing it is some where between 36 and 34 inches.
Rick G.
Rick G is offline
Old 02-18-2013 | 02:33 PM
that thing is saweeet!
frickstyle is offline
Old 02-18-2013 | 02:51 PM
No kidding super clean . Something to strive for.
RG.
Rick G is offline
Old 02-18-2013 | 03:40 PM
Rick, : 36.5" between the zerk fittings up top.
Frickstyle. We`re paint job brothers
ICDEDPPL is offline
Old 02-18-2013 | 03:53 PM
Thanks ICDEDPPL . I thought mine was wide but it appears yours is about the same maybe a half an inch wider.
RG.
Rick G is offline
Old 02-18-2013 | 04:00 PM
Rick... as close as possible... we discussed what we have to do with engines on floor... see how close you can actually get them... 34" would be great if we can get it
adk61 is offline
Old 02-18-2013 | 04:01 PM
ICDED that ride is quite spectacular... congrats
adk61 is offline
Old 02-18-2013 | 06:52 PM
My hawk is 34". Which will leave 1/2" between my Cmi sport tubes. I have std deck blocks and stock gm heads. My flat deck was also 34" but they had to dent the headers with the big chief heads and tall decks.
Unlimited jd is offline
