Eagle Steel Trailer - Tandem >
Old 02-20-2013 | 09:57 AM
ziemer's Avatar
Default Eagle Steel Trailer - Tandem
Any interest in an Eagle tube steel painted trailer?
It sits under my 30' Velocity and being in Florida I'm trying to figure out if I want to redo this one or upgrade to an aluminum. It's a stout trailer. 8" side beams and (8) 6" tall crossmembers. Tires are 16.5" diameter.
It's got 6000 lb, 8 lug axles with drums on both. Brakes were new a little over a year ago with new lines and new lights.
Tires were also new at the time along with bunks.
The tubing is showing signs of rist, but the trailer was not used most of it's life and overall is still solid.
It was towed down from NY in Oct of 2011, and I towed it again up north roughly 2200 miles roundtrip last summer.
Not sure what it really worth or if someone would even have a need for it. Would consider trading for aluminum with cash if deal is right.
Will get some more pics tonight.
ziemer is offline
Old 02-20-2013 | 10:21 AM
to bad its not what I am looking for, I have a big aluminum one tripple axel I want to trade for the factory steal one BAJA sold with the boat.
mittens is offline
Old 02-20-2013 | 10:42 AM
Registered User
What is the overall length of the trailer?
havasubrian is offline
Old 02-20-2013 | 11:24 AM
ziemer's Avatar
32'-33' The coupler isn't much past the winch stand.
ziemer is offline
Old 02-25-2013 | 06:52 AM
ziemer's Avatar
Took a few measurements yesterday.
From end of frame to bow eye/stop is 27'4". Bunks extend past end of frame about 6". So it's just under 28' from end of bunk to bow stop.
Overall length is a touch over 31'.
With my 30' there's about 2"-3" of bunk past the end of the hull. The bow stop could only be moved forward about an inch or two.
ziemer is offline
Old 02-25-2013 | 08:42 AM
Registered User
Thanks for checking, I need 32 to 33 to the bow stop and overall 35 to 36.
Old 02-27-2013 | 03:30 PM
what are you looking to get for it?
prostock 650 is offline
Old 02-27-2013 | 04:13 PM
ziemer's Avatar
Thinking around $1500.
ziemer is offline
Old 02-27-2013 | 06:39 PM
Sent you a P.M. Please call me,
Thanks,
Dale
daleroger is offline
Old 02-28-2013 | 09:54 AM
bigboat28's Avatar
Are all the bunks fixed or are they adjustable and is the trailer set up for a 24 degree deadrise? What is the deadrise of your boat?
bigboat28 is offline
