passive fresh water flush for closed cooled engines?
I have twin 525HPs with closed cooling. Boat is on a lift, so I can't access the drives to flush with muffs. Can I plumb T's with a quick connect (downstream from the seawater pump), and run garden hose freshwater through the heat exchanger/oil cooler/exhaust without cranking the engine? Not worried about flushing the drives. I run in brackish water. I would like to be able to quick connect from the outer hull without opening the hatch or running the engines. Thanks in advance!!
This is what i have on 496ho,s flushes the drives for a few min then fire up and do motors .
All looks very neat from outside . WOW finished
just plumb a shutoff valve into a tee to move direction of water and they make a thru hull hose connection, works great, just make sure you move valve back to drive pick up or you will kill the impellor quick...
