700 SCI - Drive options? >
Old 02-25-2013 | 07:32 AM
Default 700 SCI - Drive options?
Can't figure out if a Merc 700SCI can be used with a bravo-style drive, or must it be mated to to a NXT drive?? If you could use, say a BMAX, do you use the transmission that the 700s seem to be sold with?? Thanks.
bouncedcheque is offline
Old 02-25-2013 | 11:12 AM
bor's Avatar
bor
A B max shift internal so you don t use the NXT transmission which also uses a different bell housing then a bravo set up .
bor is offline
Old 02-25-2013 | 05:03 PM
The 700 can be mated to a bravo style drive with no transmission , its the same as the 600 sci.
JMPH is offline
Old 02-25-2013 | 05:22 PM
If you can afford the 700SCi, you can afford something that is real behind it.
For the love of God dont even think about a Bravo behind it...
Keith Atlanta is offline
Old 02-25-2013 | 06:15 PM
The 700 is sold with the nxt, it is not available with bravo drive, the bravo will not hold the 700
Polonzapie is offline
Old 02-25-2013 | 09:50 PM
I didn't mean a bravo drive, I meant a bmax. Still unclear whether I can not use the tranny on the 7oo sci and mate it to a bmax?
Old 02-25-2013 | 10:06 PM
All bravo style drives shift internally, no need for a transmission. Many guys out there with power well beyond 700hp and a bmax or equivelant.
Mercury warranties and sells the 700 with the nxt as a package since a 6 is overkill and a bravo xr will cost them too much in warranty repairs. But to answer your question, if you get a bravo bellhousing and coupler, starter, and make sure the ring gear on the flywheel is correct you could put it in a bravo boat, without the need of the trans.
Unlimited jd is offline
Old 02-25-2013 | 10:37 PM
Thanks Red.
Old 02-27-2013 | 07:31 AM
Just to close this thread out, for future readers -Merc says other drives can be used, but stall problems can be experienced at idle and shift due to ecm being flashed specifically for the NXT drive. Maybe whipple's reflash takes care of that issue? I don't know.
Old 02-27-2013 | 11:23 AM
Whipple Charged's Avatar
The techs would be incorrect. The 700SCi has a shift interupt that cuts the cylinders, to lower the rpm to 300-400 during a shift. Something the MEFI has had for years and was used on the Alpha drives. I've used this many times and if anything, it helps the built up drives such as Imco and Bmax shift better. The stall is prevented with the idle air motor and spark control to help it recover. If you don't want the shift interupt, you just disconnect the shift detent sensor.
I've run the 700SCi with an Imco SC on a 25 Daytona. Never had a problem as long as I've known about it. 700 bolts right up, without the tranny.
Whipple Charged is offline
