big block gm amd merc parts >
Old 02-25-2013 | 08:13 AM
Default big block gm amd merc parts
2 set Patterson mark 3 tubular headers with tails 2000ea 3500 both
2 Borg warner tranz 450 ea 750 pair
2 sets stainless marine thru pipes 4"250 ea 500 both sets
2 sets of Rectangler port gm high flow heads 400 ea or 700 both sets
1 silent choice set up 100
1 big block 454 mag mpi set up intake computer harness fuel rail sensors 500
1 high flow marine intake intake 30
2 distributor 25ea
2 block water pumps 15 ea
2 ignition coils 20ea
2 sets push rods lifters 15ea
2 holly 850 cfm 250ea
2 vee belt set ups 15ea
2 big block starters 40ea
4 raw water sea pump assembly 40ea
2 power steering pumps 40ea
4 flame arestors 20ea
4 block fuel pumps 40ea
4 Alternators 40ea
2 thermostate housing 20ea
4 starters 40ea
4 1" carb spacer plates 25ea
2 carb throttle linkage plates 15ea
4 offshore motor mount plates 50ea
2 sets standard valve covers 20ea
2 sets high rise valve covers 50ea
2 lifters valve trays 10ea
1 oil filter relocation kit 25
1 lifting eye 10
2 spark plug wire sets 20ea
6 thunder bolt IV ignition module 40ea
4 carb motor wiring harnesses 30ea
Many different parts please call with any questions 267-979-6292
sonic33 is offline
Old 02-25-2013 | 08:51 AM
Pm sent
Baja226sport is offline
Old 02-25-2013 | 10:40 AM
Do you have the details on the Trans? 71C or 72C, ratio, condition?
What engine size do the heads fit?
Are the spark plug wires new or used?
Are the distributors standard MC or something different?
Rostyv is offline
Old 02-25-2013 | 03:08 PM
PM sent
Sunrocket24 is offline
Old 02-25-2013 | 07:05 PM
Boat stuff needed!!!!!
Hello from Tampa, I need the following:
What is the marine intake?
Single or dual plane? *$30
1 distributor * * * * * * * * $25
1 set V belts. * * * * * * * $15
1thermo housing. * * * *$20
1carb throttle linkage. $15
Oil filter relocate kit. * *$20
Engine lifting eye. * * * $10
* * * * * * * * * * * * * * * * * *$135
Plus shipping????
MSG sent..... TBF
tpabayflyer is offline
Old 02-25-2013 | 07:38 PM
What gen are the heads? Casting number? Are they in useable condition?
Thnx
rivermonkey is offline
Old 03-05-2013 | 03:12 PM
Text sent to phone number for the following pics
raw pump
wire harness
flame arrestor
carb spacer
thanks
598 Formula is offline
Old 03-05-2013 | 08:45 PM
Did you sell the oil filter relocate Kit?
benthompson292 is offline
Old 03-10-2013 | 03:32 AM
Default Pm sent
Pm sent
zipfast is offline
Old 03-11-2013 | 09:42 PM
I will take a power steering pump... Please pm me Paypal details or payment details.
FuelinAround is offline
