Dry tails for bravo setup >
Old 02-25-2013 | 11:55 AM
Default Dry tails for bravo setup
Looking for 1 set of dry tails for a bravo setup that will fit my gil manifolds.
cp5899 is offline
Old 02-25-2013 | 12:13 PM
Good luck ive been lookin for 9 months
smokin' gun is offline
Old 02-25-2013 | 12:20 PM
I noticed that. Hoping maybe there's someone with one set...
I have a setup for trs that I may cut up to make work.
cp5899 is offline
Old 03-11-2013 | 10:48 AM
hullofjustis's Avatar
I have 1 set of long gil pipes that i may be willing to get rid of. They are thru transom and dry but can be open quite easily
hullofjustis is offline
Old 03-11-2013 | 11:46 AM
I have looked forever for 2 used sets. Going to bite the bullet and have custom dry tails made using my flanges...
POWERPLAY J is offline
Old 03-11-2013 | 12:33 PM
i have a set for stanless marine if you have the flanges it would be easy to cut the SM flanges off and put the gill on.
ridefast77 is offline
Old 03-11-2013 | 12:55 PM
Thanks I appreciate the offer but we are going 5" and have the stock
Old 03-11-2013 | 01:46 PM
bwd
Hey Guys, There are a few of us on here that have pipes that would work. All "dry" pipes are custom made. Most have a mist of water coming from the end and others, like the ones I use on my Phantom are dry, welded at the end but with a expansion hose/joint inside the transom. My point here is all of these pipes are most likely going to work they just need to be cut and modified to fit your needs.
Its simply enough to take them down to the local metal shop and have them cut with their band saw then weld back on what you need. It does take a little thought.
In the last few years I have bought new dry s form Harden @ 3400$ for a trs boat. Then turned around had those same pipes cut and welded for my bravo Phantom . I also have a set of 4 (big gun) wet that I was saving for a set of big pipes for the Phantom but can't bare to cut to transom hole bigger. So I'm selling those for 1000. I paid 700 a piece from stellings. They fit the gil flange.
Attached Thumbnails Dry tails for bravo setup-1216121232.jpg   Dry tails for bravo setup-img_3521.jpg
bwd is offline
Old 03-11-2013 | 01:50 PM
Moved my water bungholes further inside this yr & had ends capped.
$90 labor.
scarab63 is offline
Old 03-11-2013 | 02:09 PM
I have a set of dry tails that are Gills. Let the bitting begin.
HighPriority is offline
