25 parts all under $250 ea. >
Old 02-25-2013 | 09:21 PM
Default 25 parts all under $250 ea.
HP gimbal bellhousing $250 KE remote oil thermostat #12AN fittings $150 Livorsi throttle only control w/trim in handle $150 Sherwood BB crank driven water pumps w/2 groove pulleys $150 pr. Livorsi side mount throttle pod new $125 Single engine mount plate 32 1/2" wide $125 1/2" dock lines w/carabiners braided on new $125 TB4 v-6 14 ignition module $125 HP500 oil cooler $125 Trim pump no solenoids $100 Dual cooler bellhousing $100 Trim tab switches w/mounting plate new $50 Lovett 900 3/4" bilge pump $50 Pass. side grab handle w/trim tab switches $50 XR prop hub kit $50 TB4 v8-22 ignition module $50 TB5 v-6 ign. module $50 K-plane trim cyl. has anti fouling paint $50 Kiekhaefer zero effort control parts $50 1" propshaft solid hub kit $35 5/8" 90 deg. recessed fuel vent $25 Group 27 battery box $25 High flow fuel filter head $25 KE gen 4 remote oil adapter $25 Gen 5/6 remote oil madapter $25 Gen 5 dipstick and tube $20 pr. Livorsi 2" water psi gauge $20 Trailer u-bolts 1/2" dia $20all Gil/Canton 8" or 10" oil pickup new $20 ea. Gil/Canton flexible dipstick & tube $10 914-262-1898
Btrhd is offline
Old 02-25-2013 | 09:27 PM
Addl. pics.
Btrhd is offline
Old 02-25-2013 | 09:36 PM
Addl. pics.
Btrhd is offline
Old 02-25-2013 | 10:07 PM
Are the water pressure gauges electric or mechanical?
2330s is offline
Old 02-26-2013 | 04:49 AM
hullofjustis's Avatar
Hp helmet or standard?
hullofjustis is offline
Old 02-26-2013 | 07:14 AM
Sick Stinger's Avatar
Brotherhood #1
How much for shipping on the batt box? I'm interest
Sick Stinger is offline
Old 02-26-2013 | 07:20 AM
Do you have the heights and widths of the u-bolts?
FBRONCO is offline
Old 02-26-2013 | 09:33 AM
scottw's Avatar
Left a message at your number. Give me a call. I'll take the pick-up and the dipstick for the 10qt. Canton oil pan.
scottw is offline
Old 02-26-2013 | 10:50 AM
Do the harnesses include neutral start safety switch and trim?
Phil
floatingphil is offline
Old 02-26-2013 | 06:34 PM
Hi Phil, There is a nuetral safety switch as well as the diode setup to trim 2 drives with one switch. The throttle handle itself does not have the provision for a built in trim switch. the Livorsi throttle only setup I have does have trim in the handle. Thanks, Holden
Btrhd is offline
