502 long block
Old 02-27-2013 | 04:29 PM
Jmemoli's Avatar
Goumada P5-38
Default 502 long block
Fresh 502 long block , gen 6 low hours
Crankshaft was just polished and is has standard size mains and rods . NEw clevite bearings , mercury racing hbeam rods , je pistons with low hours .
Fresh file fit rings and mellings HV pump . The block deck was also squared up and cut .008 " and a fresh hone on the standard bore . includes factory 8 quart pan .
No cam or timing chain - send me yours and i will install -
located in New Jersey , can pallet and ship to your residence for around $300 . Fresh heads also available if you want a complete motor .
Jerry 908 343 6645 , $4000
Attached Thumbnails 502 long block-016.jpg   502 long block-017.jpg   502 long block-018-2-.jpg
Jmemoli is offline
Old 02-28-2013 | 09:19 PM
Jmemoli's Avatar
Goumada P5-38
Ttt
Jmemoli is offline
Old 03-08-2013 | 07:26 AM
Jmemoli's Avatar
Goumada P5-38
Tty
Jmemoli is offline
Old 03-08-2013 | 09:18 AM
Jmemoli's Avatar
Goumada P5-38
set of fresh water 502 magnum heads available also - will add to motor if need be .
Jmemoli is offline
Old 03-23-2013 | 10:24 PM
What casting number are the heads?
Insomniac is offline
Old 03-23-2013 | 10:27 PM
Shouldn't heads, cam, and timing chain be included if your selling a long block?
Baja226sport is offline
Old 03-23-2013 | 10:35 PM
Jmemoli's Avatar
Goumada P5-38
Sorry it's a short lock.
088 heads are available with it .
Jmemoli is offline
Old 03-23-2013 | 10:37 PM
Jmemoli's Avatar
Goumada P5-38
Since most people want different cams I let customer decide .
Jmemoli is offline
Old 04-23-2013 | 01:32 PM
Jmemoli's Avatar
Goumada P5-38
Ttt
Jmemoli is offline
