Why size prop?
If you run out of test wheels, let me know and we can send some out to you.
Brett
Brett
[email protected]
[email protected]
Carrying that extra blade provides more bite but also adds drag as the motor has to swing one extra blade through the water. It is common to use a 4 blade prop with about 1" less pitch for the same boat as compared to a 3 blade. The 4 blade will usually have a slightly smaller diameter to a comparable 3 blade. Again that is a generality.
Any guesses on what speeds I should be looking at after the bravo is on and obviously with the right prop and the horsepower as stated earlier? I can't wait to have everything put together!!!
