90 mercruiser 7.4 mags
I'd guess 475-500hp. If you are changing anything in the rotating assem then your rebalance. If not, it won't hurt to balance but if you arent doing a complete teardown I would not be concerned not balancing. You should make sure you can get away running that compression with iron heads and 93oct. It seems a little close to the edge.
Probably run. Octane. Booster. A. Little
I guess Arp bolts. And. Go.
What. Would. You. Say. Would. Be. Safe. Max. Hp. For those. ( stock. Bottom. Ends
500 550 aside. Should. Move. A. 30'er. Pretty. Good
Need. Iron eagles. And. Some. Lightened. Balanced. Pistons. And. A.
Hone
Hone
