Bravo Tie Bar
Old 03-04-2013 | 07:31 PM
Default Bravo Tie Bar
I'm looking for a Bravo Tie Bar that measures 34.5 from center to center. Thanks!
joshalger1 is offline
Old 03-04-2013 | 10:38 PM
I have a good one $500
kidapache is offline
Old 03-05-2013 | 06:41 AM
resurrected's Avatar
I have Marine Machine Wing plates for Mercury Bravo outdrives and tie bar for twin engine hydraulic set up. This set up is extremely heavy duty with 1 5/16" diameter tie bar that is 54 3/4" center to center. This is perfect for a medium size cat with bravo drives. The tie bar can also be shortened at your local machine shop at minimal expense to fit any twin engine application. Steering rams can be attached outside or inside of the wing plates on this set up. I do not have the long studs to mount them to the bellhousings. I will take $500 and you pay actual shipping.
resurrected is offline
Old 03-09-2013 | 11:19 AM
I have one I posted here a while ago. Here is the link. Just call me if interested.
http://www.offshoreonly.com/forums/swap-shop/277657-latham-tie-bar.html
indywhsle is offline
