Volvo DuoProp Wrench?
Have heard a few different opinions--is the Volvo wrench the best or does someone know of a better solution for a tool to remove the forward prop nut on a Volvo DuoProp DPS drive?
I've heard it's rather simple to "make" your own taking a deep well socket and marking/grinding to the notches on the nut.
Thoughts are appreciated.
YEP had that happen had to cut the prop on the big spline off they were alley and i tried everthing broke two pullers spent a day just would not move ,put some nice stainless steel ones back on ,had that drive on the boat 19 years never had to spend a penney on it .
Back in the early 90s i was in the States and was in a parts shop and saw a volvo penta sign up on the wall i asked how much for a set of stainles steel props $ 700+ was the reply i jumped at them , as i was given a price here in England for 1100 pounds and at the time you got 2$ to the pound which made them $2200 .
Thats about the best deal i ever Regarding boat stuff.
First time I saw the genuine Volvo tool I thought it to be pretty Mickey Mouse. They actually work pretty well. A lot less work buying one than sawing up a socket .BTW ,It would have to be one deep, deepwell socket to modify to fit over inner shaft. If you own a Volvo duo boat,you should also own the correct prop wrench ...Won't help you on seized splines though.
Take the torque value, say 100 ft-lbs, and divide it by the length of your wrench, say 9" (.75'). 100/.75= 133 and this is the force you need to apply to the wrench. A longer wrench, cheater?, obviously makes this easier to do, but you'll need to account for its weight if it gets too long.
Keep the wrench horizontal, parallel to earth, and the force going straight down to prevent any geometry errors. That's
