Ideas for new cabin door
Old 03-07-2013 | 03:29 PM
Default Ideas for new cabin door
It's the last piece of wood in the cabin and it needs to go!
I want to go with black to match the rest of the dash/cockpit. It needs to be functional and look good. Most importantly I don't want to spend a fortune on it
What have you guys done??
Jim
502ss is offline
Old 03-07-2013 | 04:03 PM
I haven't done it myself, but I have seen where the louvers have been removed and replaced with some dark plexiglass. Looked pretty good.
zz28zz is offline
Old 03-07-2013 | 04:08 PM
I've been kicking the idea around of doing a soft zip around door.
POWERPLAY J is offline
Old 03-07-2013 | 04:37 PM
Top hatch for cabin door is already black acrylic. Why not remake the doors in the same? Or for a really cool touch, white semi-translucent with the gauge cluster graphic added.....
commandersander is offline
Old 03-07-2013 | 05:44 PM
There are some folks that can recreate that using starboard (not sure if you can get sb in black). Keep the slats for ventilation if you do not have ac.
Port Monster is offline
Old 03-07-2013 | 08:06 PM
The current door is 1" thick. I think I would need to go with the same thickness in acrylic just to keep the rigidity. I will have to see what the cost would be!
The dash panel overlay is getting done to match the boat, might be too busy for the door??
502ss is offline
Old 03-07-2013 | 08:20 PM
You could get clear acrylic and sand it with a da on the inside. Makes it look like frosted glass. Looks good with black and goes with any color. Lets light in also.
Old 03-07-2013 | 08:24 PM
Your boat build has come out incredible, it inspires me to get my resto going again. my panther has a sliding acrylic door, with a similar top door.
sr73z is offline
Old 03-07-2013 | 08:45 PM
Thanks!!
Sliding door, hmmmm.....
Do you have any pictures of it?
502ss is offline
Old 03-07-2013 | 08:50 PM
Rookie's Avatar
I forget what size you need but I have dark smoked acrylic door that slides open.
I have ordered from this place before and they will also cut it to size.
http://www.ebay.com/itm/black-plexig...item53e528e100
http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
Rookie is offline
