cold water a bad idea? >
Old 03-09-2013 | 01:52 PM
Default cold water a bad idea?
Just wondering what the consequences of cold water could be. After the complete rerig, im anxious to get a test run in asap to see if theres any issues before boating season is in full swing as well as see where im at as far as props are concerned.finishing up the hyd steering this weekend and its supposed to be in the upper 40s low 50s this week but the water temp is about 40.am i looking for cracked manifolds or should i be ok?any thoughts?
Rbesola is offline
Old 03-09-2013 | 02:02 PM
Don't get in the water. You will get hypothermia.
POWERPLAY J is offline
Old 03-09-2013 | 02:07 PM
Just make sure the engines are up to temp before you drop the hammers.
79formula is offline
Old 03-09-2013 | 03:09 PM
mcollinstn's Avatar
If you are running thermostats, then get the motors over 130 and get the oil over 180 before you hammer it. Otherwise, no problems.
MC
mcollinstn is offline
Old 03-09-2013 | 04:44 PM
Dave M's Avatar
Veteran: Navy
I notice very little difference in running temps regardless of sea temp. This always seemed to be the case with any motor I've owned.
Like the others said, make sure your temps are up before getting on it.
Dave M is offline
Old 03-09-2013 | 05:57 PM
Looks like you've made a lot of progress in a short time! Let's see some pics!
Unlimited jd is offline
Old 03-09-2013 | 06:00 PM
Regardless of time of year or temps i never run anything much above idle til im up to operating temp.i just wasn't sure with the cold water considering as soon as the t-stat opens its ice cold water through everything
Rbesola is offline
Old 03-09-2013 | 06:05 PM
only thing that might crack is your body from freezing,i have been out testing in 40 deg weather,wear a parka.
mike tkach is offline
Old 03-09-2013 | 07:50 PM
i would wait,,you might run into a few logs or what ever floats..if you really want to make a test run take the boat to a warmer state to were you can get the rite egt's,,it will all change with the warm air..
FIXX is offline
Old 03-09-2013 | 10:59 PM
+1....Bring it down to South Florida. My friend Diego and I will help you get it sorted out...and our water temp is 75*
[IMG][/IMG]
[IMG][/IMG]
sprink58 is offline
