Anyone have some Weiand 10 rib pulleys for dyno use only?? >
Old 03-11-2013 | 09:14 AM
Registered User
Default Anyone have some Weiand 10 rib pulleys for dyno use only??
Im going to dyno my engines this weekend I have weiand 177's w/ 10 rib. Stock they have 3.5in. pulley, anyone have any smaller ones I could rent or borrow just for dyno time??
3.5" made 3.5 psi at 6500 rpm looking to hit the 5.5 to 6 psi
I understand these are kinda spendy at $100 each, I have no problem sending someone money for them until I get done & return them to you. Simple paypal transaction & return + shipping ill cover.
~Thanks mike~
GTOKILLER is offline
Old 03-11-2013 | 09:36 AM
If you have the splined shaft, then PM jeff1000man. I sold him 1 or two a few years ago. I have the 2.85 and 3.10 pulleys that have a single keyway (automotive style) if thats what you need.
Old Navy is offline
Old 03-11-2013 | 11:41 AM
Registered User
Thanks, Im 99% sure they are the keyway automotive style, ill call the builder & have him double check he has my chargers.
Ill send you a PM.
Old 03-12-2013 | 06:20 PM
yes they should be the key way ones mike.
Drock78 is offline
Old 03-12-2013 | 06:51 PM
Registered User
Yea they are, he called back today. Thanks
Old 03-12-2013 | 08:10 PM
I can loan you the 3.10 pulley with keyway, not splines . The smaller pulley and belt is still on my motor. I have an intercooler so if you are not running one the belt lenghts will be different. PM your address. This may cost you some beers at Hotboat Weekend!
Old Navy is offline
Old 03-12-2013 | 09:03 PM
Default fixx
i have 2 4 5/8 merc blue crank pully's..sc 600 , their 10 rib..blower will spool up faster,,
FIXX is offline
Old 03-13-2013 | 01:44 AM
A 4 5/8 bottom pulley will spin the top pulley on the SC even slower. It would only be overdriven about 45% instead of the standard 100% with the stock 7" lower pulley.
Griff is offline
Old 03-13-2013 | 08:08 AM
I have a new 2.66 but really want to sell it...
ezstriper is offline
Old 03-13-2013 | 03:52 PM
Registered User
Thanks for all the replies!! PM's have been sent out.
Mrfixxall: I will measure the under pulley I have now & let you know. Thanks
