Sliding cabin door sticking / 06' Fountain >
Old 03-11-2013 | 02:19 PM
Default Sliding cabin door sticking / 06' Fountain
I have a 42 Fountain Lightning and the sliding cabin door is VERY hard to open. I have already set the dampener shock to the least resistance possible. Should I grease the sliders?
erichuegele is offline
Old 03-11-2013 | 03:50 PM
Randy Nielsen's Avatar
You might check the rail mount screws to see if they are loose & dragging on the slider,(happened to me) for lubrication you might try graphite. A dry lube as it will not attract dirt & grime. Randy
Randy Nielsen is offline
Old 03-11-2013 | 05:30 PM
Kelly O's Avatar
For sure check for loose screws, use blue Loctite to keep them tight.
Clean the track with a penetrating oil to remove any hardened grease/grime- that grit is probably the issue. My door slides best with clean dry rails.
Kelly O is offline
