Where can I find 5.5" exhaust seals?
http://www.ebay.com/itm/Silicone-Rub...item2ec3f60834 you can use a yard stick with a nail in 1 end and a razor knife stuck in it to cut perfect cicrles.
That Ebay piece says flame retardant. I don't think it can handle the heat of headers. Try Grainger or Mcmaster Carr. Most likely you will have to make your own or try and call the header manufacturer if you know who that is ???
I made mine out of a semi truck tire innertube. Truck tire shops have them laying in the scrap pile and will gladly give you one.
I think your exhaust is 5'' O.D.? You'll want to cut the hole smaller than 5'', so it stretches over the pipe and fits snug and somewhat water tight.
