Trailer swap
Would a 26 Monza fit on A trailer made for a 30 ft Velocity
Both are 24* deadrise
Winch post can be moved back
Keel length should be about the same , I know the Velocity has a notch but overall length is from bow to stern
Thoughts
Thoughts
Be prepared to modify the keel cradle as to height and position but nothing that can't be quickly "wrenched" to adjust.
prolly be close enough to make work.. my trailer i beleive would handle a 30-31 footer on it that my 255 lib is on ... i dont for see the axles and stuff handling it weight wise but the trailer is way long enough.. only thing i found on mine.. is the tongue is way long nothing that cant be shortened if wanted.. on a side note my trucks tires are no where near water when loading unloading..
