Is the splash shield needed on 502 gen6????
I bought a bare 502 block and assembling the engine now. I am using the Morel lifters with tie bars but I am going to use the stock spider lifter retainer as I read that it aids in dripping oil on the lifters and cam. I do not have the valley tray that sits above that just below the intake and wonder if that is needed?? thanks..... TBF
if you are using link bar lifters,forget about the spider retainer,it wont be of any use and possibly will interfere with the link bars,and you don,t have to have the tray under the manifold,but it does keep hot oil off of the intake manifold keeping it cooler.
OK thanks Fellas, yes I am using link bar lifters so no spider, I found the splash shield for around $30 so I will get one and use it... I have an air gap intake and getting it ceramic coated now.... Every little bit of heat rejection will help prevent vapor lock so I will do it. I also think the splash shield will help keep the lifter valley area coated in oil so I will use it....... TBF
Getting my motor going now and I picked up the valley tray brand new for $22?? It was a little rusty but scrubbed up nicely and should last a long time bathed in oil...... Seems like keeping hot oil from hitting the bottom of the intake is a good thing.....TBF
You got one new but it was rusty? Not sure I understand. If you bought one from an online retailer, please provide us a link. I might opt for one of these as well, although I wonder if it helps as much when you are running an intake that has an air space under the plenum like the Air Gap and the Dart.
50/50 hinedite.....now if your using a single plane intake or a air gap intake you really dont need the splash shield but i always use one just to keep the intake cooler.. definitely if your using a dual plane intake..
Yes, I got it from boats.net and it had a little rusting going on but not too bad..... It is still very serviceable and needed a little scrubbing but cleaned up with a small amount of pitting remaining...... I am using the RPM Air Gap manifold and feel that using the shield will keep the wind generated oil vortex away from the top of the engine and probably do a better job of keeping the cam/ lifter valley covered in oil......... GM engineers are likely pretty sharp fellas and there is a reason they use the shield so I dont think I will be second guessing them! TBF
