Roller SB timing cover >
Old 03-22-2013 | 04:14 PM
Default Roller SB timing cover
On the OE small block Chevys, it seems if you want to run a double roller timing chain the plastic cover won't fit.
This is my first OE roller block and I'm puzzled, do you just use a steel one? And do these use a torrington bearing?
Thanks.
I did a search but nothing that I could find.
CC230 is offline
Old 03-22-2013 | 06:06 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Try here . http://www.summitracing.com/parts/sum-g6300 I used this one on my 383ci w/double roller .
the deep is offline
Old 03-24-2013 | 10:01 AM
deep,
This is a short water pump set up, no bypass. So that cover won't fit. And it looks like the factory plastic would need trimmed also. Looks like research on a steel one will have to work.
CC230 is offline
Old 03-24-2013 | 03:56 PM
Depending on who's gear you are using, double check the clearance between the back of the gear and the raised casting by the three plugs around the cam tunnel. A little grinding may be needed.
maddad is offline
