Painting bottom of boat options
About to pull my 255 liberator off trailer to finish removing the old black bottom paint ive sand it down to white fiberglass
Wanting to back with a regular paint as its a trailer boat
Anyone ever roll paint on as I wont be able to flip it?
Was thinking about a acrylic auto paint with a lil hardner
Kind of like what guys are doing in bilge any thought
What about surface prep any primer or just roll iy over the white glass
After a good dust removing
if u want the white bottom sand with 320 on palm or air sander then wet sand 600 or 1000 depending on the scratches then if it needs more hit it with 1500. at that point buff a way and then wax. its a lot of work but will turn out grate.
you cant have just bottom paint over bare fiberglass..you have to seal it first with gelcoat or duratech..if your really not concerned just buy the gelcoat you want to use and mix it 50/50 with clear duratech and it will air dry like painy but will be alot stronger then paint..you can roll it on with a foam roller then lightly brush over it and it will flow like paint,let it kick off and do it again until you have enough coats on you frrl safe with which should be 40 ml thick..
its not raw fiberglass.. its a white color almost like gel or primer if you sand it you see bare glass im assuming since the boat was blue gel coat orginally before being painted black with the bottom being bottom painted.. that the orginal blue gel may have gotten sanded off or something i dunno .. its a smotth finish white.. whatever it is..
i need something i can roll on that will come out good as i wont be able to spray it layin on the ground on my back... and i dont want antifouling bottom paint reason for sanding it down...
where to get it..http://www.expresscomposites.com/duratec.html
