Does oil go bad just sitting in motor? >
Old 03-25-2013 | 08:30 PM
Rwbrew3's Avatar
Default Does oil go bad just sitting in motor?
I changed my oil at the end of the season 4-5 month ago, maybe put 8hrs or so since the change. I know it will collect moisture if sits to long, just wondering if I should change it before I get her wet again.
Currently using VR1 50
Guess I could ask the same on gear oil!
Any input is appreciated !
Rwbrew3 is offline
Old 03-25-2013 | 08:45 PM
I'd go out and run it as is.
boats74 is offline
Old 03-25-2013 | 08:46 PM
i know a lot of people that always change it before the winter and run that oil throw the beginning of the session with no problems. now i always like to leave the older oil in the motors over the winter then change in the spring after de winterizing the boat and its fresh new oil. i think you will be good thow
1989mach1 is offline
Old 03-25-2013 | 08:47 PM
i change my fluids and filters at the end of each year before storage,then in the spring im ready to go.i have done it this way for years with no issues.
mike tkach is offline
Old 03-25-2013 | 08:49 PM
Rwbrew3's Avatar
Thanks guys! Wasn't thinking I guess, better to leave the older in and start fresh beginng of season!
Rwbrew3 is offline
Old 03-25-2013 | 08:52 PM
Rwbrew3's Avatar
Makes me feel better, I was getting a bit concerned. What bout drive oil....same?
Rwbrew3 is offline
Old 03-25-2013 | 08:57 PM
yep
Old 03-25-2013 | 09:31 PM
Ted G's Avatar
Actually because the oil has moisture and acids in it you should change at the end if the season and leave clean oil in it. That oil will be fine to start on in the spring and less likely to etch the bearings than old oil sitting in there all winter.
www.cbpba.com
Ted G is offline
Old 03-25-2013 | 09:46 PM
Rwbrew3's Avatar
Oh.... Makes sense! Does starting it every so often help as well !
Rwbrew3 is offline
Old 03-25-2013 | 09:47 PM
Thumbs up
That's the right plan
motor is offline
