aftermarket fuel pump
im going to be replacing my stock fuel pump on my 89
330 454 for maintenance reasons only. my question is will
the fuel outlet and inlet be in the same spots and angles as the factory pump so i will not have to replace any fuel lines. im looking at a basic holley replacement marine
pump. any input would be a great help thanks
Stock pump is 23 years old and still works. Replace it with another stock pump if you are set on doing it. I would just leave it alone though. It might last another 5-10 years.
You need to use a Marine fuel pump.
had one go out on my other boat same year same hours im rebuilding my carb too. i do alot off maintance every spring try to catch problems before thay happen. i was just tryin to save a few buck over a carter/mercrusier pump
Inlets and outlets can be anywhere on pumps depending on application
