525sc w/ chiller belt?? >
Old 03-26-2013 | 10:15 AM
Default 525sc w/ chiller belt??
adding a chiller to a 525sc. anyone know the part number for the belt needed with the chiller (innercooler) installed?
88bullet is offline
Old 03-26-2013 | 11:10 AM
I can help you if you post upper and lower pulley sizes. I have run both the 3.05 upper and the 2.85 upper with a 7 lower. They use a different size belt.
Old Navy is offline
Old 03-27-2013 | 06:11 PM
Call Teague. They would most likely have it in stock and be able to ship tomorrow.
kylemenz1 is offline
Old 03-27-2013 | 06:58 PM
havent had a chance to measure the pulley. its the stock merc 525sc pulley system. chiller should be here in a few days. not in a super hurry we just got a couple inches of snow in buffalo...ugh
gotta call teague for gaskets !!!
88bullet is offline
Old 03-27-2013 | 08:09 PM
You can get gaskets for the top and bottom from any speedshop. Teage has the orings for the case to core on the chiller. Its an old PFM I assume? You will also need longer blower studs and you will have to extend the water T outlet to the exhaust.
Old Navy is offline
