Stellings header leak
Old 03-27-2013 | 05:40 PM
Unhappy Stellings header leak
I have the "Steroid" header. Motor is out ...Took one to get a small crack on the outside fixed and when put on the hose more leaks showed up internally.
One near the #1 cylinder that was repaired, the other at the collector and one that could not be seen.
The welder could not 100% fix the collector leak. He says the wall is too thin and theres some pitting on the rest of the header internally.
These are 2002 , is that all a $7500 set lasts? 11 years and their done?
Not a good day for me, I checked all plugs and exhaust ports and there no indication of reversion.
Figure hes testing it on 45psi residential water pressure.. all these will see is 17psi..
Thought?! I can`t pull off a new set right now...hoping the leak is smaller at less psi and just blows out the exhaust???
ICDEDPPL is offline
Old 03-27-2013 | 06:18 PM
Sorry to hear!!!!! I know how ya feel. Reduce the pressure at the hose to 25 to 30 and see what happens.
sonic700 is offline
Old 03-27-2013 | 06:31 PM
Default fixx
here is the sad part,,wtelling is out of the header biz so you phucked on trying to replace one set in the future..after about hearing about the one i would pull all of them and check them,,better then replacing the blocks when water gets into your cylinders and hydraulisc's the block wide open..put a self drain kit on the headers so they drain when your sitting..
FIXX is offline
Old 03-27-2013 | 06:39 PM
GAZ
What is a self drain header kit? Will you explain please. I might be interested in them. I drain my complete block and headers every time I use my boat.
GAZ is offline
Old 03-27-2013 | 06:45 PM
Default fixx
its bacicly a hose that goes through the transom or drains in the hull that drains its self when its not under pressure..
FIXX is offline
Old 03-27-2013 | 07:36 PM
bcfountain's Avatar
Registered User
I feel your pain$$.thats a big ticket item.i am like u.that kind of coin they should last longer.
bcfountain is offline
Old 03-28-2013 | 06:56 PM
Well I brought the header home tested it and I don`t see the big deal. I get nothing when I hook it up to the hose full blast and when i restrict one end I get a little seapage at the collector.
When is the header going to have 45psi in it and nowhere for the water to go as he was testing it?? Never
Its a good day
ICDEDPPL is offline
Old 03-28-2013 | 07:31 PM
Default fixx
Its a good day
the crack will open up under extreme heat so make sure it's cool!..
FIXX is offline
Old 03-29-2013 | 12:48 PM
You can call Stellings and they have a contact person that can replace the collector and repair any leaks. The guy was pretty cheap. I sent mine back to him and he replaced the entire collector for $350 and it came back looking like new.
cdail28590 is offline
Old 03-29-2013 | 09:20 PM
Thumbs up
Well how awesome is that !! Do you have any contact info??
ICDEDPPL is offline
