-2 inch imco shorties on a straight bottom 35 with 540 600 hp >
Old 03-27-2013 | 08:07 PM
Default -2 inch imco shorties on a straight bottom 35 with 540 600 hp
i have a chance to buy a set of imco 2 inch shorties. any thoughts i need to pull the triggeer by the weekend.
flat rate is offline
Old 03-27-2013 | 08:25 PM
could only be a positive move .
575cat is offline
Old 03-29-2013 | 08:44 PM
How fast does your boat go now? If you replace your lowers let me know your results as I am thinking about doing the same thing ,also what are you running now for props and will you change them.
green lightning is offline
Old 03-31-2013 | 09:26 AM
I also have a 35 flat bottom running 540's and interested in the results, what prop and GPS speed are you running before and after the change.
thanks
253 is offline
