2005 nordic rage fuel range at cruise speed? >
Old 03-28-2013 | 11:38 PM
Default 2005 nordic rage fuel range at cruise speed?
Just wondering with the 60 gallons of fuel on a 05 rage how far you can make it at cruise speed
With a 496ho bravo 1x 26pm prop
I havent tried to track it. i just fill it and go
jokergerm is offline
Old 03-29-2013 | 06:54 AM
Check out page 32 in this section fuel burn at diff/RPMs for the 496Ho
paul buckner is offline
Old 03-29-2013 | 02:18 PM
If you're looking for fuel economy , bolt on a Maximus 5 blade , watch your mid-range mileage soar !
HALLETT FAN is offline
Old 03-29-2013 | 02:56 PM
Dave M's Avatar
Veteran: Navy
+1
I found that my 496HO in my last boat averaged around 12 GPH. That was an average of idle, cruise, fast, and some WOT. This was a pretty consistent number over many tanks of gas. I had a 60 gallon tank and I knew I could typically run 4-5 hours on a tank. I never really equated this to the range, just GPH.
Dave M is offline
Old 03-29-2013 | 09:31 PM
Wobble's Avatar
SORE MEMBER
90 miles with little or no safety factor.
120 miles to dry tank if very conservative.
Wobble is offline
Old 03-30-2013 | 06:33 AM
Dave M's Avatar
Veteran: Navy
One time with my last boat, I filled up (60g), went 155 miles, according to GPS. Got back home and the next time I filled up it took 55 gallons.
On the way to my destination I think I was running 4000+ rpms. On the way back I noticed the gauge was getting low so I backed off a bit.
Dave M is offline
