Go Back  Offshoreonly.com > Owners Forum > Powerplay
Measurements >
Measurements
Measurements
Old 03-30-2013 | 10:02 AM
Default Measurements
My boat is still shrink-wrapped so I was wondering if anyone, could give me the cockpit floor dimensions of a 33 Sportdeck. Trying to order some Lonseal flooring for my boat.
Thanking you in advance,
Lenny
33 powerplay is offline
Old 03-31-2013 | 09:00 AM
6ft 2in wide x 6ft 5in long, mine is a 91 IO. This was a quick measurement 7' x 7' should be more then enough.
Clustergear is offline
Old 04-01-2013 | 07:37 PM
Thanks for the measurements.
Old 04-02-2013 | 07:10 AM
Indy's Avatar
Member #154
Are you ripping out the existing or is it gone? Just FYI, I had the Pirelli or Lonseal wave in mine. I scrubbed the crap out of it, primed it with interlux primer, then applied their two part urethane finish to it and it came out absolutely stunning with good durability. Only had it for a season before I sold it but it wore well. Of course you can't drop anchors or abuse it but for regular use and clean-up it was the right thing to do.
Indy is offline
Old 04-02-2013 | 03:15 PM
Hey Indy, I have the Lonseal wave in mine now-have a few rust stains in it from an anchor shade that I cant get out. Would rather not but am going to rip it out and put lonseal coin in it
Old 04-02-2013 | 03:21 PM
fantastixvoyage's Avatar
FYI but I would NOT recommend the coin. I put it in my Awesome and it was dangerously slippery when wet. I have the diamond plate in the phantom and wave in the PP. both are much better.
Is your flooring white? I had good success cleaning mine with a bleach bathroom cleaner and using dilute bleach on the small tougher stains. Might be worthwhile getting aggressive on the old before making the decision to pull it.
fantastixvoyage is offline
Old 04-02-2013 | 08:04 PM
Indy's Avatar
Member #154
Lonseal has a coin floor with textured coins that works well...I put it in my Nordic and it was fine. It might be Loncoin II but would have to check to be sure.
Indy is offline
