SVL numbers
Old 03-30-2013 | 12:05 PM
TYPHOON's Avatar
Default SVL numbers
To all the SVL and future SVL teams at OPA. We are all working on our boats for the first race and wanted to make sure we have the proper size, color and back ground on our numbers. We all have gotten away from the rules on this. With as many as 10 teams at the start and lots of the same color boats the scoring people will need to see our numbers to be sure. Thanks
Randy
TYPHOON is offline
Old 03-30-2013 | 12:59 PM
Lucididee's Avatar
Any chance you guys can go to a 1-digit thru 2-digit numbering? Choose numbers 2-99.
Speaking from a scoring side, the 3 digit numbering makes it difficult from a scoring perspective being there is no guarantee that the same people score at every race. When teaching people how to score and the difference in classes this makes it a tad difficult for them.
And before you get into the other classes (blah blah blah), can we please work with on one class at a time.
Bottom line .... the number must be a distinctive color contrast of the boat!
Lucididee is offline
Old 03-30-2013 | 01:02 PM
This should apply to ALL OPA boats, 18" tall #'s. If anyone shows up with a "P" on there boat, I'll loan them a scrapper to remove it!
Fast Shafts is offline
Old 03-30-2013 | 01:14 PM
Lucididee's Avatar
Here you go .....
Numbers shall be vinyl or paint in black vertical block lettering over a white background. If applied to a white hull, a black border must surround them. numbering must be in direct contrast to the color of the hull. The minimum height of each number shall be eighteen (18) inches, minimum width shall be thirteen (13) inches, and minimum stroke shall be three (3) inches. Minimum spacing between each number shall be four (4) inches.
(Racers have been good with this .... with a quick glance at my photos from last season, the "P" has either been covered over or removed.)
Old 03-30-2013 | 01:16 PM
TYPHOON's Avatar
Simmons thats you. Only 2 numbers. LOL
TYPHOON is offline
Old 03-30-2013 | 01:18 PM
Thanks Dee!!
Old 03-30-2013 | 01:36 PM
Ryan Beckley's Avatar
Racer
Racer
You CAN NOT put an 18" number and border on a SVL...... the sides are not that tall.....
Ryan Beckley is offline
Old 03-30-2013 | 01:41 PM
Lucididee's Avatar
Things need to be adjusted a little Probably won't work on the Class 7 boats as well
But come on ... Do you really need to have a 4-digit number?
Lucididee's Avatar
We've talked about it
Old 03-30-2013 | 03:05 PM
TYPHOON's Avatar
Ryan what size do you think works on our smaller boats? We would have 2 numbers and a back ground. Possably you could show us to scale in a shop drawing if you had a chance. My boat is not at my shop. I agree there should be a differant size for the smaller boats under 30' but also dont want to open a can of worms.
TYPHOON is offline
