figure this one out...what is the problem???
Does it happen right when she plugs it in or while using the dryer?
Is it a ground fault outlet or ground fault breaker in the panel.
How old is the home and has there been recent renovation that involved electrical work?
Does it happen if you plug anything else into outlet.
Initially I would look at faulty hair dryer or outlet. If you change the oulet be sure it is a ground fault outlet. Actually it is code required.
Any outlet within 6ft of a sink, tub shall be GFCI.
Paul
Paul
we had this on our last "spec house" the electrician tied about 4 plugs to that circuit all over the house. It end in the bath with the ground fault outlet. they are touchy.
our problem, we had our deep freeze in the basement plugged in. IT WAS ON THAT CIRCUIT. only knew when the ciruit was tripped when we let the dog out and the outside light (ON THAT CIRCUIT) wouldn't turn on!!!
see what else goes out when this trips.
new house now. dedicated circuit breaker for the freezer.
so my advice.... get a new house, interest rates are low
that will fix it.
just kidding. unplug some stuff, or replace that ground fault circuit with another new one. like I said, they can be touchy. they are suppose to be.
that will fix it.
