Hydraulic steering assy. or parts
I'm ultimately looking for a cheap set up for twin Bravo's but I'd also be interested in whatever parts you have so I can piece together an assembly.
PM me what you have.
I could use a single setup , I have a set ( drew marine side winders ) you could use 1 per drive keeps the drives from moving and takes strain off your gimble rings $ 400.0 shipped I just want to upgrade to a single ram steering go to drew marine web site . they took 95% of my chim walk away , just going over 80 mph and I really want to upgrade my steering to something better
I have Marine Machine Wing plates for Mercury Bravo outdrives and tie bar for twin engine hydraulic set up. This set up is extremely heavy duty with 1 5/16" diameter tie bar that is 54 3/4" center to center. This is perfect for a medium size cat with bravo drives. The tie bar can also be shortened at your local machine shop at minimal expense to fit any twin engine application. Steering rams can be attached outside or inside of the wing plates on this set up. I do not have the long studs to mount them to the drives.I am looking for $500 and you pay actual shipping. Thanks, Jason
