Before and After shots of Outdrives >
Old 07-23-2002 | 02:41 PM
THE BULL's Avatar
Talking Before and After shots of Outdrives
spent some good time over the last few weeks sanding, taping and painting...........lots of work!!!!! this is what it looked like before the bondo came out
THE BULL is offline
Old 07-23-2002 | 02:55 PM
THE BULL's Avatar
finished!
THE BULL is offline
Old 07-23-2002 | 03:02 PM
MrCIG's Avatar
Charter Member#330
Bull,
Those are TRS drives did the nose cones make a difference?
MrCIG is offline
Old 07-23-2002 | 05:53 PM
THE BULL's Avatar
the trs drives are indestructable........and the borg warner velvet drives are awesome......i never ran the boat without the bullet noses...however, it has been very difficult to keep the marinetex/bondo intact as i takes a little bodywork to keep it looking pretty. this time i took it down to the metal and put in a tiny amount of marintex, applied self etching epoxy primer, and awlgripped bright aluminum and jet black.......i will run it and let you know how it held up!!!!!!!!
THE BULL is offline
Old 07-23-2002 | 05:59 PM
Audiofn's Avatar
Charter Member #232
Looking good. I have had good luck with Long Hair Mar Glas holding up ok with Nose Cones. I took them off my boat however as it really does not need them and it never will. I would think that the Marine Tex would also be a good choice for that They look good.
Jon
Put your best foot forward!
Audiofn is offline
Old 07-23-2002 | 06:02 PM
THE BULL's Avatar
another shot
THE BULL is offline
Old 07-23-2002 | 06:07 PM
THE BULL's Avatar
jon,
thanks for the kind words.........i dont think my boat really needs them either, as it only runs in the low 70s with the props i run....it was set up like that when i bought the drives......at what mph do they begin to work?? i heard like 85mph.......i would need about 1200hp+ to get there!!!!!
THE BULL is offline
Old 07-23-2002 | 08:55 PM
THE BULL's Avatar
fred, make sure to post some pics when you do it!!!!!!!!!
THE BULL is offline
Old 07-23-2002 | 10:37 PM
If you ever redo them again, try some stuff call All-Metal. It is a putty type filler that looks like it has aluminum in it and it has a acid type catylist. Stuff dries hard as a rock. I did my nosecones with it and it lasted 7 years with no blisters or anything, (then sold the boat). A autobody supply should be able to get it.
Those outdrives look killer though. Good job.
goob is offline
Old 07-24-2002 | 07:55 AM
THE BULL's Avatar
thanks goob!!! if this epoxy doesnt work, i will go with the all metal you mentioned..........7 years is great!!!!!!!!
THE BULL is offline
375stinger
0
01-23-2006 04:01 PM
Excalibur
36
11-10-2004 10:03 AM
Von Bongo
10-12-2004 08:27 AM
CFD12
05-07-2003 10:20 PM
Steet
7
11-01-2002 12:55 PM
