TRS Drives, L&R
Old 04-05-2013 | 06:35 AM
Zero Patience's Avatar
Default TRS Drives, L&R
one pair of TRS Drives, 1.5 ratio, with Gimbals, Rams, tailstocks and inner transom plates. Very good condition. $3500
Zero Patience is offline
Old 04-07-2013 | 06:04 PM
Ttt
First Gun is offline
Old 04-07-2013 | 08:56 PM
Whollycrapbatman..
That's a gift! Somebody better......
commandersander is offline
Old 04-13-2013 | 05:54 AM
Still available...
Old 04-13-2013 | 07:07 AM
That's a good deal !!
open87 is offline
Old 04-13-2013 | 12:03 PM
jvthundercat's Avatar
What's the difference between Bravo One and TRS?
jvthundercat is offline
Old 04-15-2013 | 09:54 AM
Oh boy.......something's you just can't fix
Old 04-28-2013 | 09:28 PM
Ttt
Old 04-29-2013 | 07:20 AM
Why be a D!ck when its a valid question ? I too, would like to know.. Are they compatible with Bravo gimbals/tansom parts anyone?
masonbig1 is offline
Old 04-29-2013 | 01:07 PM
trs is the older style, they have been out of production for about 20 years i believe. they use a transmission, so you have more weight than with bravos, roughly a couple hundred pounds with twins. also bravos have more engine compartment room as the engines set all the way back to the transom assys. so front of engine access is usually tons better. the trs drives are also more beefy, heavier, stronger, and less prone to breakage. trs sits deeper in the water. none of the transom assy. parts interchange. the trs cutout is larger, totally different. trs parts are getting harder to find. bravo parts are easy as they still make them, and you will need them, as they break a lot with high hp engines, compared to trs. that is a hell of a good deal on that drive package.
sr73z is offline
