AFR meters
Old 04-05-2013 | 03:52 PM
Default AFR meters
which afr meters you guys use? I did a search on here to see if this thread was started once but came up with nothing
I have older gills with long tails where abouts do you put the O2 bungs?
zeke is offline
Old 04-05-2013 | 04:10 PM
I use the F.A.S.T. EFI dual channel. Some guys use the innovate one.
MILD THUNDER is offline
Old 04-05-2013 | 04:22 PM
which do you feel is the better one for the dollar?
zeke is offline
Old 04-05-2013 | 05:05 PM
I have never used the innovate one. The Fast one is available with 22ft long cables, which is nice in a boat, it datalogs also. A buddy and I went halves on it, we used it to tune our boats. Really a great tool to have.
Old 04-05-2013 | 06:04 PM
zeke,is your exhaust a totally dry system?
mike tkach is offline
Old 04-05-2013 | 08:42 PM
no its not mike. ill try load a picture of them on my old motor
zeke is offline
Old 04-06-2013 | 12:18 AM
I use the Innovate MTX-L. Mounted the gauge in the boat and run it full time. Works great. USB connection for data logging. Real nice product.
Trash is offline
Old 04-07-2013 | 06:35 PM
how far above the water inlet should i have the bungs installed?
zeke is offline
Old 04-07-2013 | 06:45 PM
it doesn,t take a lot of moisture to ruin the 02 senser.
Old 04-07-2013 | 09:37 PM
from what i recall mine mix pretty much right at the tail end of the riser
zeke is offline
