Whipple oil change? >
Whipple oil change?
Whipple oil change?
Old 04-06-2013 | 02:53 PM
Question Whipple oil change?
I'm needed to change the oil in my 3.3 Whipple, can someone tell me what size hex & maybe a trick for getting at the drain plug? It's not in the most accessible location. Thanks.
Brian C is offline
Old 04-06-2013 | 04:05 PM
Rwbrew3's Avatar
Can you not pull it out through the top?
Rwbrew3 is offline
Old 04-06-2013 | 10:49 PM
If you have the plug that takes an allen wrench, I believe it is a 10mm. We have a stubby allen wrench set that works great. You can also cut down a regular wrench. We use a piece of cardboard as a makeshift funnel to direct the oil to a cup. It only holds a few ounces. You can fill it back up with Castrol Syntec 5W50.
Eddie
Young Performance is offline
Old 04-07-2013 | 07:53 AM
Sounds good. Thanks Eddie.
Brian C is offline
