741 cam question >
741 cam question
741 cam question
Old 04-07-2013 | 04:39 PM
Default 741 cam question
will i get more top end with the 741 cam in at 0 vs 4 degrees advanced. Mine is at 4 advanced and i think im losing top end power and speed vs being in at 0. Thanks
rssteiny is offline
Old 04-07-2013 | 05:03 PM
Default fixx
yes it will make more power in the upper end 5k+ ifd you can get pas the rev limiter.you will have to go to headers with dry exhaust tho..
FIXX is offline
Old 04-07-2013 | 05:18 PM
Probably not but, if you want some valid info you'll need to post some specifics:
Engine specs: Size, compression ratio, heads, intake, carb size, or efi, exhaust type, rocker ratio, spring pressure, etc. Boat info: Gear ratio, prop size and type, type of boat, max rpm you want to turn.
Also, when you say 0, are you talking about straight up per the cam card, or retarding it 4 degrees? I don't know the specs on the 741 'cause I've never used one, but I'd guess it's got some advance ground in. Are you 4 degrees advanced of the recommended install now, or straight up? Please clarify.
HaxbySpeed is offline
Old 04-07-2013 | 05:28 PM
Default fixx
he has his 741 cam advanced 4* because he waws getting reversion with his gil manifolds a few years back...i got 400 rpm by taking out the 4* that i advanced my cam to..
FIXX is offline
Old 04-07-2013 | 06:12 PM
2000 32 active thunder 500hps with worked heads, carbs worked by nickerson marine, turn them 5400, 30 pitch b1s , 1.7 rollers, as fixx said i advanced them 4 degrees thought it was a reversion problem but it was not and im thinking i lost top end speed. Fixx you picked up 400 rpms turning back from 4 degrees advance to 0 is that correct.
rssteiny is offline
Old 04-07-2013 | 06:19 PM
Default fixx
500hps worked heads, carbs worked by nickerson marine, turn them 5400, 1.7 rollers, as fixx said i advanced them 4 degrees thought it was a reversion problem but it was not and im thinking i lost top end speed. Fixx you picked up 400 rpms turning back from 4 degrees advance to 0 is that correct.
400+ went from 5600 to 6+ at times lol...small block tho..my donzi is a lite boat and i really did not notice any low end loss..im going back to like 99 when i did it...i build the engine in 1997 in 1999 the pin came out of the comp cam and went through my timing chain and snapped it and exploaded my alunimum timing cover..i pulled it and had hent every valve in the heads..i ordered better valves and lapped them in..i put the cam back in at 112* and she has been rippin ever since..the idle is a little ruffer tho..
FIXX is offline
Old 04-08-2013 | 07:02 AM
So you have it at 0 now no advance.
rssteiny is offline
Old 04-08-2013 | 10:29 AM
If you put it in at 4degrees advanced on the sprocket, which is in addition to the advance ground in to the cam, then you're probably
around 8 degrees advanced and would benefit from putting it back in straight up at the factory specs, which are likely 4 degrees advanced. Do you have a degree wheel? If you're truly only 4 degrees advanced total, then I don't think you'll gain anything by retarding it 4 degrees. If it runs stronger at 4 deg retarded then you could use a bigger cam.
Old 04-08-2013 | 12:09 PM
So where is this cam installed now? ICL?
MILD THUNDER is offline
Old 04-08-2013 | 04:34 PM
blue thunder's Avatar
Loading them at the recommended ICL is always the best in my opinion unless you have the wrong cam for the application. So if your rev limiter will let you get to 55-5800rpm you should set it straight up. If you are limited to 51-5200 or so you probably need a more stump puller type cam. In that case I'd change the rev limiter and set the cam up to spin the Rpms it needs.
blue thunder is offline
