Anyone towing with a Sierra Denali 1500? >
Old 04-10-2013 | 10:29 AM
Default Anyone towing with a Sierra Denali 1500?
I picked up a new, to me, 07' Sierra Denali AWD last week. I bought this to replace my V10 F250 and 330ci. My velocity 260 is pretty light and shouldn't be an issue to haul around with the half ton vs. 3/4
So far I've outfitted the truck with a set of airlift helper bags in the rear, towing mirrors off of a 2500HD, and Hellwig rear sway bar. Holding off on a transmission cooler until i see how the fluid temperture actually does while towing. Considering an electric over hydraulic conversion for my trailer, and I should mention I'm using a weight distributing hitch as well.
Is there anything else recommended that would make towing easier, more comfortable, or more safe?
SnailblazerSS is offline
Old 04-10-2013 | 02:27 PM
I would not think you should have any problems, I tow my VR1 with my Silverado SS with no problem at all.
searaycer is offline
Old 04-10-2013 | 06:10 PM
You will be fine, of the issues you addressed only one taht maybe necessary is the air bags, but I doubt it, I tow my 303 Formula and my 05 sierra hardly squats at all, just depends on if your trailer is set up properly
88242LS is offline
Old 04-10-2013 | 07:25 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
No stock transmission cooler?
You should be fine with that setup.
Sydwayz is offline
Old 04-10-2013 | 07:53 PM
thats what i was thinking . i have an 07 sierra vortech max , it has the trans cooler in it .same power setup as a denali i think ... 6.0 and 4l70 trans
state1310 is offline
Old 04-10-2013 | 08:11 PM
07-current denali is a 6.2l, max pack is the 6.0 you got,
88242LS is offline
Old 04-10-2013 | 08:25 PM
even better .
Old 04-11-2013 | 11:14 AM
yea i took a 1500 Denali for a weekend, man it was a nice truck, plenty of power especially for pulling a 260
AJ POWERPLAY is offline
Old 04-11-2013 | 11:45 AM
Thanks guys. I just want to have a comfortable and trouble free towing setup.
Old 04-12-2013 | 07:38 AM
I tow my 28 AT with a crew cab 1500 with no problems at all on a triple axle with brakes on all 3 axles. If you have a towing package I think the tranny cooler is standard.
Drock78 is offline
