Trying to get the best speed out of my 350 MAG MPI/ 21P Mirage Plus Prop >
Old 04-10-2013 | 07:40 PM
Default Trying to get the best speed out of my 350 MAG MPI/ 21P Mirage Plus Prop
I have a 2006 StarCraft Nexstar 19' boat that weighs in at 2100 w/o engine dry. It has a 350 MAG MPI 300 HP Engine and a Bravo 1 outdrive.
I currently am running a Mirage Plus 21 Pitch prop. The boat goes 58 MPH @ 4750 RPMs with just me on board. My WOT range is 4800-5200 RPM.
Am I lugging the engine at this RPM? Would I gain performance by having my prop "labbed" or changing pitch? Are there any better props out there? I would like to see 60 MPH if possible. Any suggestions? I wish there were easy upgrades for the MPI engine, but I think it is maxed out w/o internal engine work.
Any help is appreciated!!
jserr68594 is offline
Old 04-11-2013 | 10:39 AM
You are kinda in the sweet spot with the stock engine a labbed prop should get you to 60 IMO.
pi75 is offline
Old 04-11-2013 | 12:29 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
This is the obvious and easiest, most cost effective route.
You have a good prop, let's just make it better.
Brett
[email protected]
bbladesprops is offline
