My Brothers P&D 24x7 Hull, BUilt 350 with Alpha 1. >
Old 04-10-2013 | 09:39 PM
Default My Brothers P&D 24x7 Hull, BUilt 350 with Alpha 1.
My brother is working on his new project boat and he has a completely re-built 350 with between 300-380hp on it. (Not exactly sure) I was wondering if the alpha 1 would be able to hold up for at least a summer? Anything He needs to know while doing this project? I will provide pics if interested. Thanks for the help!
ibuildme is offline
Old 04-10-2013 | 09:46 PM
glassdave's Avatar
Neno the mind boggler
you should be fine just go easy on it. make sure the shift interupter is functioning properly. the 24/7 P&D hull is a fun one
08 OPA High Points Champion
glassdave is offline
Old 04-10-2013 | 09:52 PM
No Hole shots... you'll be fine. Im putting 500hp threw my alpha ss this summer.
chrisf695 is offline
Old 04-10-2013 | 10:00 PM
Thanks Guys! Much appreciated! Anything else we should know?
ibuildme is offline
Old 04-11-2013 | 05:35 AM
even if it doesn't hold up, there are no less expensive easier to find drives. buy a whole boat for a nickel. keep drive and tons of spares. sell trailer for a nickel.
dereknkathy is offline
Old 04-11-2013 | 05:39 AM
youpushin a 24/7with a 350. If you do grenade the alpha, get a $1200 SEI. with a 3 year no fault warrenty. You kill it, it's covered.
phragle is offline
Old 04-11-2013 | 06:17 AM
Runner prop hubs really help! The old Mach hub was really good and never failed.
Steve
smiklos@sunprint is offline
Old 04-11-2013 | 07:40 AM
glassdave's Avatar
Keep in mind your drive is (or should be) a 1.50/1 ratio. Also the early MR drives are a direct replacement and i think a slightly stronger drive but harder to find in a one fifty ratio. If your good with the throttle and smart with it you should have no problem in the 350 hp range. I had a pair of three hundred forty hp sbc in a 260 Scorpion and the drives were fine other then hitting a log once and getting fishing line around a prop shaft another time (wipes out lower seal). Another thing to note is use only the green Merc HP oil and change often (every twenty five hours give or take)
Old 04-11-2013 | 05:12 PM
Thanks guys!
ibuildme is offline
Old 04-11-2013 | 05:43 PM
PICs updated
ibuildme is offline
