Trim Sender
Old 04-13-2013 | 08:02 PM
Default Trim Sender
Every 3-4 years I have to replace the trim sender puck on my outdrive. The drive is lubricated every year. I've never had to replace the trim limit puck. The drive is 26 yrs old. It needs to be done again. I have a drawer full of limit pucks since you have to buy both. Is this normal? The boat is only used in fresh water maybe 10-12 times a year.
Thanks, Dave
David Stotz is offline
Old 04-13-2013 | 08:55 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
ttt
the deep is offline
Old 04-14-2013 | 08:20 PM
blue thunder's Avatar
What happens that leads you to believe it needs to be replaced?
blue thunder is offline
Old 04-14-2013 | 08:57 PM
The fact you say you have left over limit switches leads me to believe you may have spliced the new senders in .When you pull the two wires back through the plates to replace one why wouldn't you do them both .The two wires have a rubber plug that is only formed when you put them together .Surely you haven't been plugging that hole with one old one and one new one .That being said .Moisture will follow the wire through and insufficiently sealed splice and ruin the sender
motor is offline
Old 04-16-2013 | 10:19 PM
Worn hinge pins/bushings?
Cory H is offline
Old 04-17-2013 | 12:14 AM
Default fixx
unscrew it and clean it,,,give it a few hundred turns and lube it up and put it back on...should be good for a few more years..they get a slime build up amd need to be man handled one in a whyle..
FIXX is offline
Old 04-17-2013 | 05:49 AM
My early morning blurry eyes saw this thread and miss read the posters name as David Stecz... I was like Holy phucking ghosts of christmas past!! it cant be kool aid time!!!!!!!
[IMG][/IMG]
phragle is offline
Old 04-20-2013 | 11:35 AM
I know when the switch is bad because the gauge acts erratically. When I take the switch apart the wound wire inside (reostat) is broken.
Dave
Old 04-21-2013 | 08:29 AM
Thanks, Dave
check this out....
http://www.ebay.com/itm/130893729512...84.m1555.l2649
2tonchevy is offline
Old 04-24-2013 | 12:33 PM
2ton, thx
