496 mag won't crank >
496 mag won't crank
496 mag won't crank
Old 04-15-2013 | 11:43 AM
Default 496 mag won't crank
I started the motor for the first time of the season with a water hose, no issues, ran fine. Took the boat to the water and tried to crank and I get nothing but a clicking sound, the sound is coming from the module by the fuse on top of the motor. Last season I put a new starter and impeller in it. any thoughts?????
ghostrider19d is offline
Old 04-15-2013 | 12:19 PM
Clean your battery connections, then check all grounds and connections on starter. Assuming you have a good battery.
4bus is offline
Old 04-15-2013 | 12:26 PM
Randy Nielsen's Avatar
Check your landyard also, that happened to me & that's what the shop said it was. Randy
Randy Nielsen is offline
Old 04-15-2013 | 12:57 PM
txriverrat2001's Avatar
Primary starter solenoid? Looks like a trim pump solenoid.... problem is they don't list one on the 496? Still digging though.. if I find it you'll know...
txriverrat2001 is offline
Old 04-15-2013 | 01:00 PM
Well it's there and thats your problem. It is the thing you hear clicking on top of the motor. Same as a trim tab pump solenoid. About $15 on ebay. Easy fix.
Dan
BajaDan is offline
Old 04-15-2013 | 01:01 PM
Default #11 in this pic ...
http://www.mercruiserparts.com/Show_...CM+AND+BRACKET
Old 04-15-2013 | 01:15 PM
makes sense, thanks a lot, I get more help from here than in the SELOC manual.
Old 04-15-2013 | 03:42 PM
Thanks again, got one on order thanks for the part # txriverrat...
Old 04-15-2013 | 03:52 PM
No problem... they basically have two type they use - one with a flat mounting base - the other is mounted up a little bit. Both perform the exact same function and can be used if in a pinch ... just the mounting is different. If stuck somewhere - cross the two terminals on top and it'll turn right over... (The larger two of the 4) Good luck!
Old 04-15-2013 | 05:08 PM
blue thunder's Avatar
Not to be mr negative but my first thought was hydrolocked. Hope not, but it happens especially after winter layup if it was stored is a cold evironment.
blue thunder is offline
