Best way to flush w/ Dual Water pickup >
Old 04-17-2013 | 08:08 AM
Stormrider's Avatar
JC Performance Engines
Default Best way to flush w/ Dual Water pickup
Need to be able to flush the boat from the drive, which has dual water pickup.
Duct taping is not an option.
Can I use the muffs and the lwp flush cone at the same time, but capping one of them? Meaning cap one of the hose inputs.
Will this create enough suction for the muffs if i cap the lwp cone?
Or would I be better using muffs and getting this flush seal kits from Teague for the lwp?
http://teaguecustommarine.com/index....-seal-kit.html
Stormrider is offline
Old 04-17-2013 | 08:15 AM
RVRCAT28's Avatar
The flush kit is the way to go. Easy to use.
RVRCAT28 is offline
Old 04-17-2013 | 08:56 AM
Stormrider's Avatar
Thanks, but that's not an option now.
As i said, need to flush from the drive.
Old 04-17-2013 | 09:30 AM
Yes, I use muffs and the seal kit to flush my boat. The seal kit is a Merc. part # and it just seals off the low water pickup.
RickSE is offline
