Stain on vinyl
Old 04-19-2013 | 01:48 PM
boatfreak's Avatar
Default Stain on vinyl
I got a finger print on my new cf vinyl during the Miami Run in Feb. and I cannot get it out. I don't know what it is but i have done everything I know of and nothing seems to work. Any suggestions would be greatly appreciated.
boatfreak is offline
Old 04-19-2013 | 02:30 PM
Nightlife1970's Avatar
If magic eraser does not take it out. You can try Acetone. You just have to be careful. Get a small area of a towel wet and dab at the stain.
Nightlife1970 is offline
Old 04-19-2013 | 03:47 PM
acetone is scarey, you get about one wipe before it eats it. I have cleaned some nasty stained white vinyl this way and had good results...
use one of those sponges with the green scrubbey scotch bright stuff..
1. pour laquer thinner on a damp scrubber sponge and scrub
2 next use soft scrub with the scrubber sponge
3. rinse well and then wipe down with 303
phragle is offline
Old 04-19-2013 | 03:55 PM
wrinkleface's Avatar
use beer!!!
wrinkleface is offline
Old 04-19-2013 | 04:03 PM
Wesley's Bleach White (white wall clear) has gotten some nasty stuff out for me in the past. At least you have some ideas now.
BBCLiberator is offline
Old 04-19-2013 | 05:54 PM
boatfreak's Avatar
Thanks guys. I have tried bleach white, soft scrub, magic eraser and simple green with no luck. I was told by a friend to use vinagar and water. I do have a sample of the vinyl I can try things on before I screw up the real thing.
Old 04-19-2013 | 06:01 PM
I tried that once after some dumb c#*%t fell in my boat walking across the boats to the bar in black heels, brand new Sunsation. Acetone melts vinyl. Not a good choice...
If the magic eraser or Soft scub doesn't touch it I don't know what will...
POWERPLAY J is offline
Old 04-19-2013 | 07:15 PM
I would have pushed the BI*&H in the water!
Drock78 is offline
Old 04-19-2013 | 07:29 PM
I wasn't there. My crew came and got me within a few min. Her douche bag man almost hit the water then the managers escorted them all out.
Old 04-19-2013 | 08:03 PM
Try WD-40 then wipe clean with a cloth soaked with dish soap and water on it or try Spray Nine and once again wipe clean with a damp cloth soaked with dish soap and water.
AB From Windsor is offline
